Manually Reading ECU Codes
I don't know much about the legacy spec or set up but it sounds like that's the code list for the 3ltr h6 engined model .
Is there , a separate ECU code list for the turbo models ?
Maybe with a different list of code numbers
Hey man! Thanks for the quick reply!
I've looked and only found a generic list.
That's about it.
Sent from my ONEPLUS A6003 using Tapatalk
  • Replies 56
  • Views 258.4k
  • 1 Engine Speed Signal Circuit 11 Crankshaft Position Sensor 12 Starter Signal 13 Camshaft Position Sensor 14 Fuel Injector No. 1 (Legacy, Impreza, Justy, SVX) 15 Fuel Injector No. 2 (Legacy, Impr
  • Connect black to black only to read fault codes, then green as well for function test mode & resetting ecu.
  • Blimey, thanks for that I'll have a go, but don't hold your breath!
They should be under the steering wheel tucked on the left hand side (RHD). I'm not to sure about LHD. Sometimes they are tapped up.
  • 3 months later...
Hi all I'm new to subaru and so far I'm having a headache.
It's a 1996 sti gc8 Impreza
The fault code is coming up as 51 and will come on and shut off the turbo at 4k rpm. Not a baldy what is wrong with it any help would be appreciated.
Callum
  • 2 months later...
I Drive a 2001 legacy GTB. I seem to be coming up with a code 107 (10 long, 7 short) but I can't find what that code is for? If someone could tell me it would be much appreciated if it's  the same as the obd2 codes it would be the map sensor?
  • 3 years later...
On 10/2/2013 at 12:18 PM, Miggs said:
53 Antenna
53 Anti-Quick Operation Mode
53 Communication Error (Time Over)
53 EGI Control Module EEPROM
53 IMM Circuit Failure (Except Antenna Circuit)
53 IMM Control Module EEPROM
53 Key Communication Failure
53 Reference Code Incompatibility
53 Use of Unregistered Key
hi, anyone knows how to bite this?
 nm
