Alarm
I have a question about an alarm. after opening the car I have about 20s to start if not I have to press the button in the key. is it normal?
Normal. If the key isn't inserted into the ignition and turned at least to the ignition position(before the start position) the immobiliser kicks in again. If that happens, you have to disable the immob by button push.
yeh normal for sigma cat1 alarm
if car don't start you just press fob button while key in ignition and turned on and it turn immobiliser off so can crank car .
