2006 Legacy Blitzen shock absorbers
Oddsock
Hi There, I need a bit of advice / knowledge about my 2006 Legacy Blitzen Saloon 2.0.
I need to replace my front shocks (front right bolt has sheared at the central top mount) and as this is an import my number plate doesn't yield any results when looking at various online part finders. Does anyone know if they are the same as any of the sportier UK models (Spec B for example).
Andy
Spec b should be the same, as it uses the bilstein suspension.
Alternatively, have a look on importcarparts.co.uk, you can shop by model then.
