Nps 6 speed change
On 10/16/2019 at 7:49 PM, Stanspeedautocare said:
Has anyone changed the neutral  position  switch  on a 6 speed box . Can it be done without removing the box
Done it . 1 hours job . So incase anyone else has to change ones . Hear is how to do it .
Remove intercooler
Remove the rear engine support arm
Jack up car
Undo centre section of exhaust
Put Jack under gearbox
Undo both gearbox brackets off car so gearbox can drop . ( only drops about 6 inches but it is enough )
The nps is on the top black plug and wire facing downwards not the one facing forwards that's the rev light switch white plug and wire .
Cut a 19mm spanner so about 4 inches use open end crack it off and undo . Reverse is all backwards . Easy job . (Not as easy as 5 speed though lol )
 Avcs now working again . Happy days
