Forester STI cruise control
Gaje
HI I have just brought a 2007 JDM Forester STI in the UK. I like to install cruise control to it and I have the control column but would like to know if its impossible to add it now aftermarket?
Appreciate anyone who has done it.
Ranj
You'll need the 'cruise control'control box that has what looks like an accelerator cable on it, you will then need a 'double' length throttle pin(2wire clips on it)going though the throttle to connect the cable to the throttle housing & the wires from the controler connecting to the appropiate pins on the ecu.
A lot of hassle for something that won't really be used that often.
i ripped my controller out so I could get the room for an RCM track attack oil catch can.
