Anyone installed any of the Subaru LED accessory interior lights?  In the catalogue they're Interior LED bulbs -  SEHAAL1000  The original ones seem dreary and weak, casting a grotty yellow.
At a quoted £109 supplied and fitted, for the Outback, that quite steep price.
Are you talking about the map lights and dome light?
If so you can pop the plastic trim that covers it, and just have a quick look for comparison. I replaced mine last week with 31mm LED interior units.
Something like this: https://autobeam.co.uk/collections/led-interior/products/led-269-interior-unit-31mm?variant=32379536638088
Boot light was a T10 LED
This is for a wrx, but I imagine they are very similar!
Pull the trim and measure bulb out that you want to replace!
Unless I'm way off here £109 seems unbelievably steep for a couple LEDs and around 2 minutes of work.
Just had a quick look around: I believe its a DE3175 festoon bulb  31mm.
Pulled from a car lighting page!
Cheers Jinshim, that's brilliant (no pun intended!).
No worries!
