Trouble getting into reverse
Have you tried putting it in reverse without the engine being on, and still have trouble? I would say the Synchromesh might be worn.
If its why the car is running it could be the same thing but would swing more over to the clutch. Is the clutch slipping at all ?
It seems okay while turnt off, the clutch isn't slipping but is a bit high on the pedal
Going for clutch problem. But do what Steve says just to test :D
Stalls when trying to pull away in 4th so I'm guessing its the gearbox then
hmm if it goes in gear when the car is off i am not sure
if you turn the car off, put in reverse, foot on clutch and start car
can you do that ok? then put in 1st then try and put back in reverse
I still think its the clutch. Might not be worn enough yet to not slip
