Subaru Outback 3.0 Advice Needed.
I’m looking to buy a Subaru. I’ve always liked the Outback. I’ve a budget of £2500. I’m based in Liverpool, so I’m also after a specialist.
https://www.ebay.co.uk/itm/204071279205?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=L2VeRXefTay&sssrc=2349624&ssuid=-hh-nLs6TQy&var=&widget_ver=artemis&media=COPY
https://www.autotrader.co.uk/car-details/202206206972189
A brief look at the MOT history confirms why its had a coating of goo to the undersides, not to mention the repeated MOT advisories.
Rear subframe is the first thing to check on these, wouldn't surprise me to find it spent its early years in Scotland exposed to the road oversalting fetish.
Thanks. The MOT History isn’t the best. I’ve asked the dealer for some more information on the car. What works it had done etc. I will wait and see if they respond.
Anything on the MOT History that’s a worry?
The repeated advisories speak to me of a possibly generally neglected car quite apart from the many failures from early in the cars life, personally i'd look elsewhere but you must make up your own mind whether a trip to view is worth it even if for comparison purposes only.
Little point in even looking underneath now its had a coating of whatever, Waxoyl? so it will look the dogs danglers if you shove your head under as all you will see is shiny black 'underseal', it probably had a plate or three welded in where the rear subrame rotted through, they all rot there if no one bothers to look after them, anyone's guess what the rest of the subframe or inner sills will be like...if you do go and look open the back doors and look for bubbling appearing where the sills meets the C pillars.
I think I will go and have a look as the car is not too far for me. I think finding a decent one in my price range is hard.
I will have to keep an eye out for any that are for sale. A members one would be ideal.
Corrosion is number one thing look out for on these, surface rust is going be the norm and that can be surface treated, heavy corrosion can get quite expensive and if it not localised rust you be chasing you tail for no long term benefit .
Also don't think newer means better, late 90's to 2002 era about some of best made .
Do good checks using MOT history and good visual inspection and that means a real good long look and poke around underneath, rust doesn't always show itself but steel can be rotted and collapse under physical inspection .
Is fairly easy find these pretty clean and not many keen on larger engines so prices can be low/easy haggle .
I would be more sceptical of dealer sales than private and that comes from 30 years trade experience lol, 99% of the good stuff comes private sales, biggest ballache and pork pies always dealers .
The dealer has sent me some pictures of the stamp book. It seems to be an okay car. They have said they will MOT it and a Full Service.
Yup, spent its life in Scotland.
Agree with MrB, the previous model up to 2003 was a high quality car, think brick outhouse solid, often wish we'd not sold ours but it did another family member a favour who needed a dependable tank for school etc duties.
It isn't as pretty as this model arguably but i wouldn't discard the earlier one from your searches.
My time would be spent inspecting this one. later shape, ebay 285009551035
I can’t seem to find any around my budget. Not locally anyway. I don’t really want to travel for hours and hours and find out the car is no good.
see my above edited post, as for travelling that is usually the case with rare cars, if you wanted an Insignia there's one on every forecourt in the land, our last 2 Subarus involved a 150 miles train trip for me (bought and driven back) the other a 70 mile drive each way.
yes i saw those, the older car has a not great MOT history, the newer one is a sold as seen vehicle with known faults and will cost you £630 to tax this year.
The one i linked to has a good mot history albeit with a short current test and few owners who kept the car a long time (always a good sign), one would hope the owner would put a new ticket on it to aid the sale, failing that some negotiation should be possible.
both links for same car,
no info on service history, mentions suspension/brake corrosion from 2020 mot history, top rate VED because regd after Match 06 cut off date, but what really puts me off is someone put cheap Sunny tyres on the thing and one odd Debica, do a close up of the wheels have you clocked the state of them, check out the corroded scored rear disc/drums visible through those wheels, fronts also look corroded but not scored, calipers very rusty, suspect you'll find some more rust under that car, however it cleaned up very well.
Don't worry about the inner CV boots that needed replacement, they all perish out sooner or later on these and are a doddle to change.
Very expensive but looks a good car, again high VED band, bit surprised how often fluctuating front brake readings crops up in the MOT history, might only need new discs and pads but calipers could be past their best, none of which are terribly expensive or difficult fixes.
look like Khumo all season tyres all round but can't be certain, i'd be happy with those.
7 owners isn't good to see, but might be explained by private reg plates going on and off a couple of times.
Gumtree car is a shed, welding needed to subframe/mounts and the interior is filthy, chinese cheap tyres, wouldn't cross the street to look at it.
The latest ebay car looks like the real deal, the only pity is it was regd in August and not before March 23rd 06, but if you're prepared to pay £630 VED then that is the one i'd be looking at.
How's it going, did you view any of these cars, be interested to know if the one with no mentions of corrosion in its mot history was appreciably better underneath than the rest.
