Timing belt change
Hi Replacing my timing belt and all the other bit including Water Pump. Issue is if i put Reg in It comes back as a 2 port water pump. The one that was on the car until today has 3 ports. Car is Legacy es Nav estate 2.0 petrol CVT. Any one else have this issue. Plus timing kit pulleys are Made in india  should i return kit
DAvid
