diesel fuel pump pressure readings
Would anyone have a note of the fuel pressure expected on my diesel Legacy. I have recorded the pressures with my machine (Foxwell), the pressure is registered in psi ,but I assume factory spec is in Bars.
The engine was a Euro 6 ,but uses a Euro 5 turbo and dpf.
Also what triggers the fuel injection into the dpf?
The engine is coming out soon and I want to check every issue to stop from duplicating any work.
Does anyone read these?
