2005 3.0R lambda sensor wires
Hi all,
I recently had an issue with the control arm of my 2005 Subaru legacy 3.0R estate.  It failed and the wheel ripped out the lambda sensor.  The control arm has been replaced and i have an aftermarket lambda sensor to fit.  The only problem is that the wheel ripped off the original plug connector.  I therefore have bare wires that lead to the ECU.  The aftermarket lambda sensor has generic wire colours so i don't know which wires to connect to the correct spade connectors in the sensor plug.
Does anyone have a wiring diagram that shows the which coloured wires go from the ECU to the lambda sensor?
Your help would be appreciated
Thanks in advance
