Forester 2003 rear hub
Hi, new here, ive got a 2003 forester 2.0X which im trying to change the rear wheel bearing. Unfortunately it was all seized and the garage applied so much pressure to get the bearing out that all the assembly shattered! So I am now trying to find the parts needed. I require the rear wheel hub nearside, can anyone confirm that the part number 28469fe000 is correct? And that it is the same as the impreza and legacy?
also i bought a pair of used driveshafts for a 2.5, as the seller claimed they were identical. Upon receiving them they are slightly different, would these still work and are both offside and nearside identical?
had to buy a knuckle from main dealer and reluctant to spend another ÂŁ700 for these parts from them!
thank you, William
