fuel tank saddle pump./ fault code P2635.
60 plated Legacy diesel..does the saddle pump supply any pressure to fuel line?
Fault code P2635 pump A low performance ..
hopefully someone will answer this for me.
the engine will not rev past 2000 ..if it does go higher it will almost die and will take a few seconds to stabilise ..fuel starvation ?
Any thoughts ??
Does anyone know if the diesel Legacy has an electric lift fuel  pump...if so where is it?
