2019 E-Boxer Forester - EV not engaging
Hi all,
Recently (this year) an owner of a lovely 2019 Subaru Forester E-Boxer Premium Lineartronic.
Everything's been fine until about 3-4 weeks ago where the EV mode stopped engaging during slow speeds. I can both not hear/feel/or see the EV mode engage in the heads up display like it used to.
Went for its 96,000 miles service today in the local dealership and the person that serviced it said he found nothing wrong with it as there were no error codes and frankly found him quite dismissive.
Can somebody please help me figure out what my options are?
Thank you!
  • 1 year later...
Did you resolve this issue
@ianm00 My friend you are in unbelievable luck. I literally just came back from my driveway after fitting a Yuasa 7055 in my Subie for the engine restart battery.
After lots of research online, electrical tests, it turned out that the problem was my 12V engine restart battery. This Yuasa model was the one that fit the specs of the OEM battery and allowed the EV mode to be re-engaged, I tried many others but none worked. It's a little bit smaller than the B24R specification, but it fits fine.
The moment I had a bit of charge on the high voltage battery and slowed down a bit during driving, EV worked normally for the first time in more than 1 year.
I am super happy.
Good luck!
Update: Spoke too soon, it works but just not consistently and not at its full potential, I believe the Yuasa 7055 is underpowered, I have ordered a Yuasa 7031 which has 72Ah VS 40Ah on the 7055, and 720CCA VS 400CCA.
I measured everything and it should fit just about... I will attempt to fit it and report back next week. I also ordered a Yuasa 7030 for the auxiliary battery, because I thought why not.
  • 2 months later...
I'm curious @Achilleas did you resolve. Just bought a 2023 Forester and disappointed with Hybrid and mpg. Manual says "when speed is less than 25mph it is possible to drive using only the power of the electric motor" but that's not my experience. It only kicks in when stopped or at very slow speed. Maybe have battery problem? What's your experience of this?
tks
Peter
