FrankB Posted December 2, 2024 Posted December 2, 2024 The Satnav map for the UK disappeared. It seems the automatic update, which is via the house wifi, is interrupted presumably when I drive away. It happened before but I managed to do a download. This time there is a failed message “Map Update Unsuccessful (107)”. The “map update info” option shows a request code to download maps and more – 1oQqkve67DS7Umzfc3d4. Not sure how to use this. Downloaded the Subaru Starlink app but cannot add my vehicle. It asks for the QR code to be scanned from the multimedia screen in my car or to enter a 8-digit code displayed on the multimedia screen. I cannot find them. Tried the customer helpline 01285 647630, got through quickly only to be told it was too technical and I have to raise a ‘case’ on the Subaru website. I will update when I get a reply. Meanwhile I will start another post about the headlights.
FrankB Posted December 8, 2024 Author Posted December 8, 2024 Good news, I got my maps back. The Subaru Customer Support replied quickly with a detailed step by step procedure to regain the maps. It looked a bit daunting but with patience it worked. The only hitch in the process is that the USB stick has to be plugged in after opening the map update window. It didn’t register when I first put it in. I will copy the steps below for anyone else to use. This is the email reply I received: Thank You for contacting Subaru (UK) Ltd. I will try and help you with your map issue, if you have lost your UK map, it sounds like you may have started a UK Map update 'in car' via a Wi-Fi connection, and then it lost connection/lost connectivity - the first thing it does is delete the current map, then apply the update, if the update fails, you have no map... The only way to fix this now is to carry out a FULL map reload via USB stick, using the maps website. I'm going to give you all the information, so apologies if you are much further ahead. For your information, the maps installed on your car can be updated to the latest map release using website: http://subaru-maps.com When using the subaru-maps website you create a user-account, add your vehicles VIN, type in your Request Code off the Head Unit to obtain your Authentication Code, then download and install the 'Map Downloader' app, open this and log in (also using the same credentials as the website) to view and physically download any updated maps available for your car. Once the USB stick has been created, insert it in the car, then type in the Activation Code you obtained from the website when prompted to authorise the install. I know this all sounds complicated, so I have attached some visual instructions as a PDF - I hope these help explain the process a little better. Lastly, the app and the QR code - unfortunately the app is only compatible for the EV vehicles, eg the SOLTERRA currently, it will not work with your Outback. I will attach the pdf mentioned above. Hope someone finds it useful. Activation Code on HARMAN maps-Dec-02-2024-03-43-40-7464-PM.pdf 1
David-Crosstrek-Owner Posted June 24 Posted June 24 thanks for posting this - I was looking at doing the same with my 2025 Crosstrek - the SatNav data is dated "2022".
Yeadonblue Posted Wednesday at 03:31 PM Posted Wednesday at 03:31 PM Tried all the different ways to update the maps on my 2020 Outback, followed step by step instructions provided by Subaru Customer Service but nothing fully worked, very frustrating. In the end took the car into my local Subaru dealer, KT Green, Otley, who managed to do the job and charged me £150 for the work 😐
Justin Time Posted Wednesday at 06:03 PM Posted Wednesday at 06:03 PM 2 hours ago, Yeadonblue said: Tried all the different ways to update the maps on my 2020 Outback, followed step by step instructions provided by Subaru Customer Service but nothing fully worked, very frustrating. In the end took the car into my local Subaru dealer, KT Green, Otley, who managed to do the job and charged me £150 for the work 😐 Ouch!!! £££££ i've had similar problems and basically have now given up. I do find it useful occasionally, such as when in remote areas where there's no phone signal, but the GPS will function.
