2008 Impreza GB 270
I'm helping a friend/family with his car (not mine).
Due to circumstance his car has been stood without being started for 8 years.
I recently removed one spark plug (the easiest one / what a PITA that was / is there a special plug spanner?).
I put my endoscope camera in and all looked fine. I turned the engine over by hand and all felt 'smooth' and the timing belt didn't have any cracks where it had been sat on the pulleys (I have recommended that he gets it changed asap).
I also recommend that he/we change the fuel but I'm not sure of the best or easiest way to do that so would be v/grateful for any advice on this or anything else that needs to be done?
The last time I seriously delved into an engine they still had distributor caps and plug leads (might even had horses at the front)! :)
I would be grateful for any advice.
I recently commissioned a rebuilt engine on a classic Fiat and the first thing I did was to write a list in stages.
Stage 1 - check all fluids, turn engine by hand for a few cycles, see if there is spark and fuel there.
Stage 2 - Ensure battery is charged, disconnect coil so no spark, watch for fuel spraying through into engine
Stage 3 - Assuming no noises or locking up the connect coil and turn over to ensure oil light extinguishes and hopefully the engine fires up....switch off almost immediately to check for leaks and any other checks you can do
Good luck
