choppy coming to stop
right just noticed this- coming to a stop on low revs with gear engaged- ( 1st or 2nd ) soon as revs drop down to about 1500rpm car start to jump like its going to stall.I've read some horror stories about some part on gearbox failling. any ideas please?
I'd say MAFS
do you reckon cleaning it would help? would you also have any links where to get replacement please mate?
Cleaning worked for about 2 days with me and it was back. They're not cheap either :( Should be able to unplug it while the car is at temp. It should stall out or struggle if it doesn't and just revs and idles fine I'd say its the MAFS for sure.
I'd maybe start 1st with getting it on an OBII reader just to see if it pulls any codes of Bluetooth one on ebay did mine a treat. Just to clear them incase any old ones are on it too.
But could be the throttle position sensor need's clean too along with the throttle body. but I would try the above 1st. I posted someone a guide on how to clean the TPS I will find it for you later :D
alrite mate i will have a look at it, great find thanks a lot ;)
A failed MAF can sometimes do that, but it's more likely to be an air leak somewhere. Check all the hoses are nice and tight and there are no signs of any getting old and cracking before you spend money on a MAF.
Yep see I overlooked that :D Best way I found to check the pipes was some water in a spray bottle.
Forgot to add... Another way air can get into the system is if one of the inlet manifold gaskets have failed, so test those too.
