Towbar question
Mtb154
I've taken one off, i left the hangers on though, from what it looks like the holes were already there, can't be too sure, lift the spare wheel tray out and the underboot storage compartments and see if there are any rubber grommets should be two either side, thats where the bar bolts in if they aren't there then it needs drilling.
I'll have a look and take a pic tomorrow for you if you want
May have bit wrong in my description of the towbar points but you get the idea from the pic.
It's only bolted onto the floor by one big bolt looks like the balck protective stuff has been removed to do this so i couldn't tell you if they are pre pressed mounting points or not. I'd have a look in general location on yours to work it out :-)
