why doesnt my timing line up?
why doesnt this line up, im confused, someone please help me with timing, this is how it lines up when all other lines are marked correctly??
1993 wrx import closed deck
Sometimes they aren't 100% accurate. Are you fitting a new belt? New belts will have timing marks on them, line these up with the single marks on the pulley's (obviously with the pulleys as close to the correct position as possible), fit the tensioner last and you should be good to run.
