Hi guys,
Over the weekend I've just picked up my first Subaru... It's a 05 wrx with a prodrive pack, and I have to say it is shockingly quick.
When I first took it out for a test run I didn't even think of listening to the stereo as the flat four gurgle sound was a dream to hear.
However sticking on the stereo in traffic it sounded shockingly bad.
I'd like to keep the original head unit in as I quite like original look.
I think I need a speaker upgrade in the door panels but not to sure about a sub unless you can get a tidy one which somehow fits below the metal shelf in front of the boot lid.
I was wondering if anyone has any ideas.
Your thought's please.
can get under seat subs, there good for what they are, as for speakers depends on your budget, i got some hertz in the RS for shows, paid £100 with comps , they are amped as well, problem with the scoob doors is there isnt much sound deadening as standard due to them been built for rallying, so some good 150w+ speakers should do for the doors, the biggest kick comes from changing the rears for 12cm items i think ? mine are 300w and give a right kick due to the size of the boot.
Ash, in the blobeye, the rear speakers are in the back doors
i have fitted 6.5" coax speakers in the front doors (just need an adaptor ring, std speakers are 5") and they made a decent improvement. also get some sound deadening to put on the inside of the door behind the speaker. i used to have a pair of 15" subs running 'infinate baffle' (no box needed) and didn't take up much boot space.
have a look at the under seat subs, they offer a decent punch and help blend into the musical sound stage
Is the sound quality improved a lot by changing speakers? I've the heard the head unit needs changing because it is !Removed!!
i changed the head unit first, so i haven't heard the std head unit with uprated speakers
i think it will be a better sound upgrading the head unit first. great speakers will only sound as good as the head unit can produce,
Just put an underseat sub in mine and makes a big difference if your not after massive bass its a great upgrade
