OBD Code's
Thought these maybe of help to a few people. Any that are not there feel free to PM or Reply I will add them :D
Code Description
P0031 Front oxygen (A/F) sensor heater circuit low
input
P0032 Front oxygen (A/F) sensor heater circult high input
P0037 Rear
oxygen sensor heater circuit malfunction
P0038 Rear oxygen sensor heater
circuit high input
P0065 Air assist injector solenoid valve
malfunction
P0066 Air assist injector solenoid valve circuit low
input
P0067 Air assist injector solenoid valve circuit high input
P0100 Mass
or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit
Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low
Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or
Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute
Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute
Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold
Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold
Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold
Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air
Temperature
Circuit Malfunction
P0111 Intake Air
Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature
Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114
Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature
Circuit Malfunction
P0116 Engine Coolant Temperature Circuit
P0117 Engine Coolant Temperature Circuit Low
Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine
Coolant Temperature Circuit Intermittent
P0120 Throttle/Petal Position
Sensor/Switch A Circuit Malfunction
P0121 Throttle/Petal Position
Sensor/Switch A Circuit Range/Performance Problem
P0122 Throttle/Petal
Position Sensor/Switch A Circuit Low Input
P0123 Throttle/Petal Position
Sensor/Switch A Circuit High Input
P0124 Throttle/Petal Position
Sensor/Switch A Circuit Intermittent
P0125 Insufficient Coolant Temperature
for Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature for
Stable Operation
P0128 Thermostat malfunction
P0130 O2 Sensor Circuit
Range/Performance Problem - Malfunction (Bank 1 Sensor 1)
P0131 O2 Sensor
Circuit Range/Performance Problem - Low Input (Bank 1 Sensor 1)
P0132 O2
Sensor Circuit Range/Performance Problem - High Input (Bank 1 Sensor 1)
P0133
O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 O2 Sensor Circuit No
Activity Detected (Bank 1 Sensor 1)
P0135 O2 Sensor Heater Circuit
P0136 O2 Sensor Circuit Range/Performance
Problem - Malfunction (Bank 1 Sensor 2)
P0137 O2 Sensor Circuit
Range/Performance Problem - Low Input (Bank 1 Sensor 2)
P0138 O2 Sensor
Circuit Range/Performance Problem - High Input (Bank 1 Sensor 2)
P0139 O2
Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 O2 Sensor Circuit No
Activity Detected (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit
P0142 O2 Sensor Circuit Range/Performance
Problem - Malfunction (Bank 1 Sensor 3)
P0143 O2 Sensor Circuit
Range/Performance Problem - Low Input (Bank 1 Sensor 3)
P0144 O2 Sensor
Circuit Range/Performance Problem - High Input (Bank 1 Sensor 3)
P0145 O2
Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 O2 Sensor Circuit No
Activity Detected (Bank 1 Sensor 3)
P0147 O2 Sensor Heater Circuit
P0150 O2 Sensor Circuit Range/Performance
Problem - Malfunction (Bank 2 Sensor 1)
P0151 O2 Sensor Circuit
Range/Performance Problem - Low Input (Bank 2 Sensor 1)
P0152 O2 Sensor
Circuit Range/Performance Problem - High Input (Bank 2 Sensor 1)
P0153 O2
Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 O2 Sensor Circuit No
Activity Detected (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit
P0156 O2 Sensor Circuit Range/Performance
Problem - Malfunction (Bank 2 Sensor 2)
P0157 O2 Sensor Circuit
Range/Performance Problem - Low Input (Bank 2 Sensor 2)
P0158 O2 Sensor
Circuit Range/Performance Problem - High Input (Bank 2 Sensor 2)
P0159 O2
Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 O2 Sensor Circuit No
Activity Detected (Bank 2 Sensor 2)
P0161 O2 Sensor Heater Circuit
P0162 O2 Sensor Circuit Range/Performance
Problem - Malfunction (Bank 2 Sensor 3)
P0163 O2 Sensor Circuit
Range/Performance Problem - Low Input (Bank 2 Sensor 3)
P0164 O2 Sensor
Circuit Range/Performance Problem - High Input (Bank 2 Sensor 3)
P0165 O2
Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 O2 Sensor Circuit No
Activity Detected (Bank 2 Sensor 3)
P0167 O2 Sensor Heater Circuit
P0170 Fuel Trim Malfunction (Bank 1)
P0171 System
too Lean (Bank 1)
P0172 System too Rich (Bank 1)
P0173 Fuel Trim
Malfunction (Bank 2)
P0174 System too Lean (Bank 2)
P0175 System too Rich
(Bank 2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel
Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor
Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180
Fuel Temperature Sensor A Circuit Malfunction
P0181 Fuel Temperature Sensor A
P0182 Fuel Temperature Sensor A Circuit Low
Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel
Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B
Circuit Malfunction
P0186 Fuel Temperature Sensor B Circuit
Range/Performance
P0187 Fuel Temperature Sensor B Circuit Low Input
P0188
Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B
P0190 Fuel Rail Pressure Sensor Circuit
Malfunction
P0191 Fuel Rail Pressure Sensor Circuit
Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193
Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor
P0195 Engine Oil Temperature Sensor Malfunction
P0196
Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature
Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil
Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201
Injector Circuit Malfunction - Cylinder 1
P0202 Injector Circuit Malfunction
- Cylinder 2
P0203 Injector Circuit Malfunction - Cylinder 3
P0204
Injector Circuit Malfunction - Cylinder 4
P0205 Injector Circuit Malfunction
- Cylinder 5
P0206 Injector Circuit Malfunction - Cylinder 6
P0207
Injector Circuit Malfunction - Cylinder 7
P0208 Injector Circuit Malfunction
- Cylinder 8
P0209 Injector Circuit Malfunction - Cylinder
9
P0210 Injector Circuit Malfunction - Cylinder
10
P0211 Injector Circuit Malfunction - Cylinder 11
P0212 Injector Circuit
Malfunction - Cylinder 12
P0213 Cold Start Injector 1 Malfunction
P0214
Cold Start Injector 2 Malfunction
P0215 Engine Shutoff Solenoid
Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217
Engine Overtemp Condition
P0218 Transmission Over Temperature
Condition
P0219 Engine Overspeed Condition
P0220 Throttle/Petal Position
Sensor/Switch B Circuit Malfunction
P0221 Throttle/Petal Position
Sensor/Switch B Circuit Range/Performance Problem
P0222 Throttle/Petal
Position Sensor/Switch B Circuit Low Input
P0223 Throttle/Petal Position
Sensor/Switch B Circuit High Input
P0224 Throttle/Petal Position
Sensor/Switch B Circuit Intermittent
P0225 Throttle/Petal Position
Sensor/Switch C Circuit Malfunction
P0226 Throttle/Petal Position
Sensor/Switch C Circuit Range/Performance Problem
P0227 Throttle/Petal
Position Sensor/Switch C Circuit Low Input
P0228 Throttle/Petal Position
Sensor/Switch C Circuit High Input
P0229 Throttle/Petal Position
Sensor/Switch C Circuit Intermittent
P0230 Fuel Pump Primary Circuit
Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump
Secondary Circuit High
P0233 Fuel Pump Secondary Circuit
Intermittent
P0234 Engine Overboost Condition
P0235 Turbocharger Boost
P0236 Turbocharger Boost Sensor A Circuit
Range/Performance
P0237 Turbocharger Boost Sensor A Circuit Low
P0238
Turbocharger Boost Sensor A Circuit High
P0239 Turbocharger Boost Sensor B
Malfunction
P0240 Turbocharger Boost Sensor B Circuit
Range/Performance
P0241 Turbocharger Boost Sensor B Circuit Low
P0242
Turbocharger Boost Sensor B Circuit High
P0243 Turbocharger Wastegate
Solenoid A Malfunction
P0244 Turbocharger Wastegate Solenoid A
Range/Performance
P0245 Turbocharger Wastegate Solenoid A Low
P0246
Turbocharger Wastegate Solenoid A High
P0247 Turbocharger Wastegate Solenoid
B Malfunction
P0248 Turbocharger Wastegate Solenoid B
Range/Performance
P0249 Turbocharger Wastegate Solenoid B Low
P0250
Turbocharger Wastegate Solenoid B High
P0251 Injection Pump Fuel Metering
Control "A" Malfunction (Cam/Rotor/Injector)
P0252 Injection Pump Fuel
Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253 Injection
Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254 Injection Pump
Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255 Injection Pump Fuel
Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256 Injection Pump
Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257 Injection
Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258
Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259
Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260
Injection Pump Fuel Metering Control "B" Intermittent
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder
1 Injector Circuit High
P0263 Cylinder 1 Contribution/Balance Fault
P0264
Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit
High
P0266 Cylinder 2 Contribution/Balance Fault
P0267 Cylinder 3 Injector
Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0269 Cylinder 3
P0270 Cylinder 4 Injector Circuit Low
P0271
Cylinder 4 Injector Circuit High
P0272 Cylinder 4 Contribution/Balance
Fault
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector
Circuit High
P0275 Cylinder 5 Contribution/Balance Fault
P0276 Cylinder 6
P0277 Cylinder 6 Injector Circuit High
P0278 Cylinder
6 Contribution/Balance Fault
P0279 Cylinder 7 Injector Circuit Low
P0280
Cylinder 7 Injector Circuit High
P0281 Cylinder 7 Contribution/Balance
Fault
P0282 Cylinder 8 Injector Circuit Low
P0283 Cylinder 8 Injector
Circuit High
P0284 Cylinder 8 Contribution/Balance Fault
P0285 Cylinder
9
P0286 Cylinder 9 Injector
Circuit High
P0287 Cylinder 9 Contribution/Balance Fault
P0288 Cylinder 10
P0289 Cylinder 10 Injector Circuit High
P0290
Cylinder 10 Contribution/Balance Fault
P0291 Cylinder 11 Injector Circuit
Low
P0292 Cylinder 11 Injector Circuit High
P0293 Cylinder 11
P0294 Cylinder 12 Injector Circuit Low
P0295
Cylinder 12 Injector Circuit High
P0296 Cylinder 12 Contribution/Range
Fault
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1
Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3
Misfire Detected
P0304
Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306
Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308
Cylinder 8 Misfire Detected
P0309 Cylinder
9
Misfire Detected
P0310 Cylinder 10 Misfire
Detected
P0311 Cylinder 11 Misfire Detected
P0312 Cylinder 12 Misfire
Detected
P0320 Ignition/Distributor Engine Speed Input Circuit
Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit
Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No
Signal
P0323 Ignition/Distributor Engine Speed Input Circuit
Intermittent
P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single
Sensor
P0326 Knock Sensor 1 Circuit
Range/Performance (Bank 1 or Single Sensor)
P0327 Knock Sensor 1 Circuit Low
Input (Bank 1 or Single Sensor)
P0328 Knock Sensor 1 Circuit High Input (Bank
1 or Single Sensor)
P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or
Single Sensor)
P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331
Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2
Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank
2)
P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335 Crankshaft
Position Sensor A Circuit Malfunction
P0336 Crankshaft Position Sensor A
P0337 Crankshaft Position Sensor A Circuit Low
Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339
Crankshaft Position Sensor A Circuit Intermittent
P0340 Camshaft Position
P0341 Camshaft Position Sensor Circuit
Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343
Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor
P0350 Ignition Coil Primary/Secondary Circuit
Malfunction
P0351 Ignition Coil A Primary/Secondary Circuit
Malfunction
P0352 Ignition Coil B Primary/Secondary Circuit
Malfunction
P0353 Ignition Coil C Primary/Secondary Circuit
Malfunction
P0354 Ignition Coil D Primary/Secondary Circuit
Malfunction
P0355 Ignition Coil E Primary/Secondary Circuit
Malfunction
P0356 Ignition Coil F Primary/Secondary Circuit
Malfunction
P0357 Ignition Coil G Primary/Secondary Circuit
Malfunction
P0358 Ignition Coil H Primary/Secondary Circuit
Malfunction
P0359 Ignition Coil I Primary/Secondary Circuit
Malfunction
P0360 Ignition Coil J Primary/Secondary Circuit
Malfunction
P0361 Ignition Coil K Primary/Secondary Circuit
Malfunction
P0362 Ignition Coil L Primary/Secondary Circuit
Malfunction
P0370 Timing Reference High Resolution Signal A
Malfunction
P0371 Timing Reference High Resolution Signal A Too Many
Pulses
P0372 Timing Reference High Resolution Signal A Too Few
Pulses
P0373 Timing Reference High Resolution Signal A Intermittent/Erratic
Pulses
P0374 Timing Reference High Resolution Signal A No Pulses
P0375
Timing Reference High Resolution Signal B Malfunction
P0376 Timing Reference
High Resolution Signal B Too Many Pulses
P0377 Timing Reference High
Resolution Signal B Too Few Pulses
P0378 Timing Reference High Resolution
Signal B Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution
Signal B No Pulses
P0380 Glow Plug/Heater Circuit "A" Malfunction
P0381
Glow Plug/Heater Indicator Circuit Malfunction
P0382 Exhaust Gas
Recirculation Flow Malfunction
P0385 Crankshaft Position Sensor B Circuit
Malfunction
P0386 Crankshaft Position Sensor B Circuit
Range/Performance
P0387 Crankshaft Position Sensor B Circuit Low
Input
P0388 Crankshaft Position Sensor B Circuit High Input
P0389
Crankshaft Position Sensor B Circuit Intermittent
P0400 Exhaust Gas
P0401 Exhaust Gas Recirculation Flow
Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive
Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust
Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation
P0406 Exhaust Gas Recirculation Sensor A Circuit
High
P0407 Exhaust Gas Recirculation Sensor B Circuit Low
P0408 Exhaust
Gas Recirculation Sensor B Circuit High
P0410 Secondary Air Injection System
Malfunction
P0411 Secondary Air Injection System Incorrect Flow
Detected
P0412 Secondary Air Injection System Switching Valve A Circuit
Malfunction
P0413 Secondary Air Injection System Switching Valve A Circuit
Open
P0414 Secondary Air Injection System Switching Valve A Circuit
Shorted
P0415 Secondary Air Injection System Switching Valve B Circuit
Malfunction
P0416 Secondary Air Injection System Switching Valve B Circuit
Open
P0417 Secondary Air Injection System Switching Valve B Circuit
Shorted
P0418 Secondary Air Injection System Relay "A" Circuit
Malfunction
P0419 Secondary Air Injection System Relay "B" Circuit
Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank
1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main
P0423 Heated Catalyst Efficiency
P0424 Heated Catalyst Temperature Below Threshold
(Bank 1)
P0426 Catalyst Temperature Sensor Range/Performance (Bank
1)
P0427 Catalyst Temperature Sensor Low Input (Bank 1)
P0428 Catalyst
Temperature Sensor High Input (Bank 1)
P0430 Catalyst System Efficiency Below
Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank
2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated
P0434 Heated Catalyst
Temperature Below Threshold (Bank 2)
P0436 Catalyst Temperature Sensor
P0437 Catalyst Temperature Sensor Low Input (Bank
2)
P0438 Catalyst Temperature Sensor High Input (Bank 2)
P0440 Evaporative
Emission Control System Malfunction
P0441 Evaporative Emission Control System
Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected
(small leak)
P0443 Evaporative Emission Control System Purge Control Valve
Circuit Malfunction
P0444 Evaporative Emission Control System Purge Control
Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control
Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control
Circuit Malfunction
P0447 Evaporative Emission Control System Vent Control
Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit
Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit
Malfunction
P0450 Evaporative Emission Control System Pressure Sensor
Malfunction
P0451 Evaporative Emission Control System Pressure Sensor
Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor
Low Input
P0453 Evaporative Emission Control System Pressure Sensor High
Input
P0454 Evaporative Emission Control System Pressure Sensor
Intermittent
P0455 Evaporative Emission Control System Leak Detected (gross
leak)
P0456 Evaporative emission control system malfunction
P0457
Evaporative Emission Control System Leak Detected (gross leak)
P0460 Fuel
Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit
Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel
Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit
Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow
P0467 Purge Flow Sensor Circuit Low
Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor
P0470 Exhaust Pressure Sensor Malfunction
P0471
Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor
Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor
Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476
Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure
Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust
Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit
Malfunction
P0481 Cooling Fan 2 Control Circuit Malfunction
P0482 Cooling
Fan 3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check
Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan
Power/Ground Circuit Malfunction
P0500 Vehicle Speed Sensor
Malfunction
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle
Speed Sensor Low Input
P0503 Vehicle Speed Sensor
Intermittent/Erratic/High
P0505 Idle Control System Malfunction
P0506 Idle
Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher
Than Expected
P0508 Idle control system circuit low input
P0509 Idle
control system circuit high input
P0510 Closed Throttle Position Switch
Malfunction
P0512 Starter switch circuit high input
P0520 Engine Oil
Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure
Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure
Sensor/Switch Circuit Low Voltage
P0523 Engine Oil Pressure Sensor/Switch
Circuit High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit
Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit
Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low
Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 Air
Conditioner Refrigerant Charge Loss
P0545 Exhaust gas temperature sensor
circuit low input
P0546 Exhaust gas temperature sensor circult high
input
P0550 Power
Steering
Pressure Sensor Circuit Malfunction
P0551
Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering
P0553 Power Steering Pressure Sensor
Circuit High Input
P0554 Power Steering Pressure Sensor Circuit
Intermittent
P0560 System Voltage Malfunction
P0561 System Voltage
Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0565
Cruise Control On Signal Malfunction
P0566 Cruise Control Off Signal
Malfunction
P0567 Cruise Control Resume Signal Malfunction
P0568 Cruise
Control Set Signal Malfunction
P0569 Cruise Control Coast Signal
Malfunction
P0570 Cruise Control Accel Signal Malfunction
P0571 Cruise
Control/Brake Switch A Circuit Malfunction
P0572 Cruise Control/Brake Switch
A Circuit Low
P0573 Cruise Control/Brake Switch A Circuit High
P0574
Cruise Control Related Malfunction
P0575 Cruise Control Related
Malfunction
P0576 Cruise Control Related Malfunction
Related Malfunction
P0578 Cruise Control Related Malfunction
P0579 Cruise
P0580 Cruise Control Related Malfunction
P0600
Serial Communication Link Malfunction
P0601 Internal Control Module Memory
Check Sum Error
P0602 Control Module Programming Error
P0603 Internal
Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module
Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only
Memory (ROM) Error
P0606 PCM Processor Fault
P0608 Control Module VSS
Output "A" Malfunction
P0609 Control Module VSS Output "B"
Malfunction
P0620 Generator Control Circuit Malfunction
P0621 Generator
Lamp "L" Control Circuit Malfunction
P0622 Generator Field "F" Control
Circuit Malfunction
P0650 Malfunction Indicator Lamp (MIL) Control Circuit
Malfunction
P0654 Engine RPM Output Circuit Malfunction
P0655 Engine Hot
Lamp Output Control Circuit Malfucntion
P0656 Fuel Level Output Circuit
Malfunction
P0700 Transmission Control System Malfunction
P0701
Transmission Control System Range/Performance
P0702 Transmission Control
System Electrical
P0703 Torque Converter/Brake Switch B Circuit
Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission
Range Sensor
Circuit malfunction (PRNDL
Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707
Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor
Circuit High Input
P0709 Transmission Range Sensor Circuit
Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit
Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit
Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low
Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714
Transmission Fluid Temperature Sensor Circuit Intermittent
P0715
Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed
P0717 Input/Turbine Speed Sensor Circuit No
Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque
Converter/Brake Switch B Circuit Low
P0720 Output
Speed Sensor
Circuit Malfunction
P0721
Output Speed Sensor Range/Performance
P0722 Output Speed Sensor No
Signal
P0723 Output Speed Sensor Intermittent
P0724 Torque Converter/Brake
P0725 Engine Speed input Circuit Malfunction
P0726
Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit
No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect
Gear Ratio
P0731 Gear 1 Incorrect ratio
P0732 Gear 2 Incorrect
ratio
P0733 Gear 3 Incorrect ratio
P0734 Gear 4 Incorrect ratio
P0735
Gear 5 Incorrect ratio
P0736 Reverse incorrect gear ratio
P0740 Torque
Converter Clutch Circuit Malfuction
P0741 Torque Converter Clutch Circuit
Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck
On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter
Clutch Circuit Intermittent
P0745 Pressure Control Solenoid
Malfunction
P0746 Pressure Control Solenoid Performance or Stuck Off
P0747
Pressure Control Solenoid Stuck On
P0748 Pressure Control Solenoid
Electrical
P0749 Pressure Control Solenoid Intermittent
P0750 Shift
P0751 Shift Solenoid A Performance or Stuck
Off
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A
Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B
Malfunction
P0756 Shift Solenoid B Performance or Stuck Off
P0757 Shift
Solenoid B Stuck On
P0758 Shift Solenoid B Electrical
P0759 Shift Solenoid
B Intermittent
P0760 Shift Solenoid C Malfunction
P0761 Shift Solenoid C
P0762 Shift Solenoid C Stuck On
P0763 Shift
Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift
Solenoid D Malfunction
P0766 Shift Solenoid D Performance or Stuck
Off
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D
Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E
Malfunction
P0771 Shift Solenoid E Performance or Stuck Off
P0772 Shift
Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid
E Intermittent
P0775 Pressure Control Solenoid B Malfunction
P0776
Pressure Control Solenoid B Performance
P0777 Pressure Control Solenoid B
Stuck On
P0778 Pressure Control Solenoid B Electrical
P0779 Pressure
Control Solenoid B Intermittent
P0780 Shift Malfunction
P0781 1-2 Shift
Malfunction
P0782 2-3 Shift Malfunction
P0783 3-4 Shift
Malfunction
P0784 4-5 Shift Malfunction
P0785 Shift/Timing Solenoid
Malfunction
P0786 Shift/Timing Solenoid Range/Performance
P0787
Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789
Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit
Malfunction
P0801 Reverse Inhibit Control Circuit Malfunction
P0803 1-4
Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804 1-4 Upshift
(Skip Shift) Lamp Control Circuit Malfunction
P1086 Tumble generator valve #2
(LH) position sensor circuit low input
P1087 Tumble generator valve #2 (LH)
position sensor circuit high input
P1088
Tumble generator valve #1 (RH) position sensor circuit low input
P1089
Tumble generator valve #1 (RH) position sensor circuit high input
P1090
Tumble generator valve #1 (RH) malfunction (stuck open)
P1091 Tumble
generator valve #1 (RH) malfunction (stuck close)
P1092 Tumble generator
valve #2 (LH) malfunction (stuck open)
P1093 Tumble generator valve #2 (LH)
P1094 Tumble generator valve circuit #1
(opencircuit)
P1095 Tumble generator valve circuit #1 (overcurrent)
P1096
Tumble generator valve circuit #2 (opencircuit)
P1097 Tumble generator valve
circuit #2 (overcurrent)
P1110 Atmospheric pressure sensor low input
P1111
Atmospheric pressure sensor high input
P1112 Atmospheric pressure sensor
range/performance problem
P1130 Front oxygen sensor circuit malfunction (open
circuit)
P1131 Front oxygen sensor circuit malfunction (short
circuit)
P1134 Front oxygen (A/F) sensor microcomputer problem
P1137 Front
oxygen (A/F) sensor circuit range/performance problem
P1139 Front oxygen
(A/F) sensor #1 heater circuit perfomance/range problem
P1141 Mass air flow
sensor circuit range/perfomance problem (low input)
P1142 Throttle position
sensor circuit range/performance problem (low input)
P1146 Pressure sensor
circuit range/performance problem (high input)
P1230 Fuel pump control unit
malfunction
P1244 Wastegate control solenoid valve malfunction (low
input)
P1245 Wastegate control solenoid valve malfunction
(fail-safe)
P1301 Fire due to increased exhaust temperature
P1312 Exhaust
temperature sensor malfunction
P1400 Fuel tank pressure control solenoid
valve circuit low input
P1420 Fuel tank pressure control solenoid valve
circuit high input
P1443 Evaporative emission control system vent control
function problem
P1480 Cooling fan relay 1 circuit high input
P1507 Idle
control system malfunction (fail-safe)
P1510 Idle air control solenoid valve
signal 1 circuit low input
P1511 Idle air control solenoid valve signal 1
circuit high input
P1512 Idle
air control solenoid valve signal 2 circuit low input
P1513 Idle air control
solenoid valve signal 2 circuit high input
P1514 Idle air control solenoid
valve signal 3 circuit low input
P1515 Idle air control solenoid valve signal
3 circuit high input
P1516 Idle air control solenoid valve signal 4 circuit
low input
P1517 Idle air control solenoid valve signal 4 circuit high
input
P1518 Starter switch circuit low input
P1540 Vehicle speed sensor
malfunction 2
P1544 High exhaust temperature detected
P1560 Back-up
voltage circuit malfunction
P1590 Neutral position switch circuit high
input
P1591 Neutral position switch circuit low input
P1592 Neutral
position switch circuit (MT model)
P1594 Automatic transmission diagnosis
input signal circuit malfunction
P1595 Automatic transmission diagnosis input
signal circuit low input
P1596 Automatic transmission diagnosis input signal
circuit high input
P1698 Engine torque control cut signal circuit low
input
P1699 Engine torque control cut signal circuit high input
P1700
Throttle position sensor circuit malfunction for automatic transmission
P1701
Cruise control set signal circuit malfunction for automatic
transmission
P1703 Low clutch timing control solenoid valve circuit
malfunction
P1711 Engine torque control signal 1 circuit malfunction
P1712
Engine torque control signal 2 circuit malfunction
ECU Data Fault Codes
2 Digit non EOBD codes (European
On-Board Diagnostics)
1 Engine Speed
Signal Circuit
11 Crankshaft Position Sensor
12 Starter Signal
13
21 Engine Coolant Temperature Sensor
22 Knock
Sensor
23 (MAF) Mass Air Flow Sensor Circuit
24 Idle Control System
Malfunction
24 ISC Valve (Stick)
24 Open/Short in ISC Valve Circuit
26
Intake Air Temperature Sensor
27 ATF Temperature Sensor Circuit
28 Knock
Sensor #2
29 Crankshaft Position Sensor 2
31 Throttle Position Sensor
Circuit
32 A/F Sensor #1 System
32 A/F Sensor #2 System
32 Oxygen
Sensor
33 Vehicle Speed Sensor
35 CPC System
36 Turbine Speed
Signal
37 Rear O2 Sensor Circuit / A/F Sensor Circuit Malfunction
38
Torque Control Signal #1
38 Torque Control Signal #2
38 Torque Control
Signal System
38 Torque Permission Signal
39 Traction Control System
42
Idle Switch
43 Accelerator Pedal Switch
44 Turbocharging Pressure Control
Signal
45 Pressure Sensor
48 Lean Burn System
49 CO Resistor
51
Neutral Position Switch
53 Antenna
53 Anti-Quick Operation Mode
53
Communication Error (Time Over)
53 EGI Control Module EEPROM
53 IMM
Circuit Failure (Except Antenna Circuit)
53 IMM Control Module EEPROM
53
Key Communication Failure
53 Reference Code Incompatibility
53 Use of
Unregistered Key
54 Air Intake System
55 EGR Valve Lift Sensor
56 EGR
System
61 Air Suction Control Solenoid Valve
62 Exhaust Manifold Valve
Negative Pressure Control Solenoid
64 Relief Valve Control Solenoid Valve
1
64 Relief Valve Control Solenoid Valve 2
65 Differential Pressure
Sensor
66 Twin Turbocharger System(H)
66 Twin Turbocharger System(S)
66
Twin Turbocharger System(T)
66 Two Stage Twin Turbocharger System
67
Exhaust Manifold Valve Positive Pressure Control Solenoid
68 Turbocharging
Pressure Control Output Signal #2
71 Shift Solenoid Valve
72 Shift
Solenoid #2 Circuit
73 Low Clutch Timing Solenoid Circuit
74 Brake Clutch
Timing Solenoid Circuit Malfunction
75 Line Pressure Duty Solenoid
Circuit
76 Brake Clutch Pressure Duty Solenoid Circuit Malfunction
77
Lock-Up Duty Solenoid Circuit
78 Tiptronic Solenoid System
79 Transfer
Clutch Duty Solenoid Circuit
81 Torque Up Control Valve
85 Charger System
Circuit Malfunction
86 CAN (Communication System)
87 Variable Induction
Solenoid Valve Circuit Malfunction
88 Fuel Pump Circuit Malfunction
89 VVT
Systems (L)
89 VVT Systems ®
91 TCS Relief Valve
92 Electrical
Generation Control Signal Circuit Malfunction
93 Vehicle Speed Sensor #1
Circuit
94 Lateral G Sensor Signal Circuit Malfunction
Newage Impreza Pics/Location.
11. Crankshaft Position Sensor
13.
21. Engine Coolant Temperature Sensor
22. Knock
Sensor
23. (MAF) Mass Air Flow Sensor
31. Throttle Position Sensor
33. Vehicle Speed Sensor
37. Rear O2 Sensor
45. Pressure Sensor
Classic Turbo 97/98
13. Camshaft
Position Sensor
23. (MAF) Mass Air
Flow Sensor
45. Pressure Sensor
