Wind noise caused by rubber grommet?
I was at a second hand parts dealer the other day. We were talking cars and when i mentioned excessive wind noise (snigger) he said that's usually caused by missing grommets at the front.
Unfortunately we were in the middle of a completely different conversation at the time and I didn't get the opportunity to ask him what grommets he was referring to. Anyone got any ideas please?
It's a common issue with subarus due to the pillar less glass, is the little rubber triangle near the mirror still intact or does it have a small split in the top ?
Theres a diy fix it guide in the guide section or you can buy some new bits from subaru and tale the whole door apart to fix. However it never really goes away I've got wind deflectors fitted and still get a gale blowing on the n/s [emoji35]
Ah I'll forget it then. Thanks Stants.
My triangles are fine and I've messed around with the window rubber. I was hoping he was referring to something else.
