Not sure what this is for ?
Hi Ive just purchased a 2002 bugeye wrx, Ive started to do a bit of maintenance on it and replaced the driver side rocker cover, but in doing so have found a cable with a broken end, which Im not sure where it goes. Its right next to the air box under the cover, there are 3 connectors, its the lowest grey one.
Any help appreciated
post-3291-0-30234500-1414649263_thumb.jp
Hi mate welcome, not sure on that could be one of fifty things [emoji52] can you chase it bavkwards to see if it goes into the loom or have been spliced into something indicating an aftermarket add on
Hi the grey plug goes straight into the loom under the little cover, its only a 2 pin connector
