54 reg subaru forester heater problem
Had my subaru forester x 54 reg couple of months now and having a problem with heater all work as it should heater direction, blower but the temp dail ive got to set to max for heat to come out if i turn it down one or 2 clicks it blows cold on screen ive looked near steering wheel where theys a rod when you turn dail it moves in and out but only when it gets to max heat i can hear a flap open well that what it sounds like and i get max heat and it never overheated and gauge never moves thanks for any help getting abit cold out they dont want to have no heat in this weather
Thanks for any advice
Johnny
Hi mate welcome, could be the heater matrix gone funny, do you have air con? Could be low on gas or have you had any work done on the car recently that has needed the coolant to be drained ? Maybe an air lock
Air con works fine and heat works ok if set to max bit hot but works but turn it down couple of clicks it goes cold on screen never had any work don't to it since I've had it cars only done 40,000 miles it like if I turn heater temp down it sounds like a flap closing just a thought on sound I hear
Thanks for any help
Johnny
Like you say the dial will have a rod attacbed to open and close the hot air, can you see where the rod goes maybe the flap is stuck and only give all or nothing
I can see rod go in and out fine but it not to sure where flap might be cause rod is fitted to a black box and you cannot see anything
Johnny
