Coilovers or not?
Gartland
Hi folks quick Q for you. I have a 04 sti uk impreza and it needs 4 new shocks. These are working out about 6/700 quid and I can get a set off middle off the road coilovers for that. But I drive fairly fast and mostly B roads so I don't want to loose the handling just so the car is dropped an inch or so. Whats your thoughts, can you get coilovers that offer a comfy good ride?
A friend of myn has got some bc coilovers and there really good only problem is , you need to sett height properly and damping rate as they need setting up properly ,and now he has got to change some bushes and a ball joint , because of **** roads and hard coilovers lol , that's why I'm going for sti shocks with lowering springs :-)
On B roads you can't beat oem inverted struts really unless spend about 2k
Bilstien do some good struts.
BC are not the worst coilovers for the money but on B roads it a downgrade on handling grip & you soon be needing them rebuilt.
 All the cheap coilovers like BC miester R etc are virtually same taiwan !Removed! with no real testing & development on specific models.
