Wrx Pro-R panel filter noise
Bikeboy16
Hi, looking for some opinions/advice if possible.
I have just fitted a Pro-R panel filter to my 59 plate WRX. The car is standard in all other ways. I fitted it myself which was a simple I thought, everything went in and out as it should.
When I took it out afterwards, I noticed a noise, which I can only describe as similar to a very quite dump valve type of sound, with a bit of a hiss/whoosh sound when changing gear.
I've checked under the bonnet with it running and there doesn't seem to be any air leaks, and it doesn't make the noise if I blip the throttle when stationary.
So.... Is this just an induction noise due the the less restricted filter ? Has anyone else experienced it ?
I do like the sound, but just not sure if it should do it !!!
Thanks in advance for your help.
Thanks for your thoughts, that's what I'm hoping.
I just wasnt sure why it is so noticeable when I change gear. I'm no mechanic, so I couldn't figure in my head what the air would do when you let off the accelerator/ dip the clutch, if you see what I mean.
