Rocker cover gaskets.
I am going to do the rocker cover gaskets on my WRX and am trying to get hold of the new gaskets, I have found some genuine ones on ebay.
The same person is selling the right hand gasket and left hand gasket, but only the righthand gasket comes with spark plug seals, is that correct or should I get seals with the lefthand gasket as well?
Markicp on ebay will have the genuine gaskets your after .
Left hand gasket ,right hand gasket ,4× spark plug gaskets ,4× half moons and some 3 bond sealant (to smear on the moons and faces )
You will loose a little bit of oil and it might be worth doing the spark plugs and making sure you've got a decent 3/4G drive socket set [emoji6]
