Exup1000 Posted June 28, 2013 Share Posted June 28, 2013 Hey dudes, got a bit to much movement in the gear stick so I'm going to change the bushes, and I thought I'd put a short shifter in while I was there as the satandard one is about a meter long!. I've found a couple,COBB, KARTBOY, and TWM so far . Anyone got any preferences that works well ? Quote Link to comment Share on other sites More sharing options...
Gambit Posted June 29, 2013 Share Posted June 29, 2013 Hi Terry Tibbs ;) I've not really used them but have been looking at these for awhile now. I have it on my maybe to do list on page 5 after my to do list :) only thing I really found was people have said even the cheapish ones worked well but the better makes feel better so don't really think you can go wrong with any choice. But that's just from what I seen :) Quote Link to comment Share on other sites More sharing options...
scottishtaffy Posted June 29, 2013 Share Posted June 29, 2013 been wondering about this too. after rebuilding my box and re installing it i noticed after i bolted box together that one of the linkages was jammed up in the bush pulled it all out then noticed that the lever inside has a hell of a play now. so either new bush or a quick shift now i think Quote Link to comment Share on other sites More sharing options...
JohnDil Posted January 1, 2015 Share Posted January 1, 2015 I have just bought one from Scoobyworld, http://preview.tinyurl.com/pdbc9t3 £70! I have seen some for less tan £20! Can the job be done from just inside the car, or do you have to go undrerneath? Thanks. Quote Link to comment Share on other sites More sharing options...
quit Posted January 1, 2015 Share Posted January 1, 2015 I just cut 2" off the selector Quote Link to comment Share on other sites More sharing options...
demondriverdave Posted January 1, 2015 Share Posted January 1, 2015 I have the 6 speed box in my FSTi and it has a lovely short shift as standard 1 Quote Link to comment Share on other sites More sharing options...
Scooby Pete Posted January 1, 2015 Share Posted January 1, 2015 I have fitted a B&M shifter to my classic, that was just removing old great stick from inside the car and refiting the short shifter stick which had different geometry to shorten the the throw. I have also fitted a Kartboy to my hatch STI. Same as the B&M change in geometry to shorten the throw. This involved both inside and outside as I bought the combo kit and changed the bushes and gearbox mount for polyurethane versions. http://www.kartboy.com/x4/product.php?productid=16174&cat=258&bestseller=Y Both jobs were pretty easy, but as with anything you get what you pay for. The Kartboy is a much better product than the B&N as the B&N came loose a cple of times. 1 Quote Link to comment Share on other sites More sharing options...
