turbo timers
so ive bought a turbo timer hks type 1 but with connecting it to the handbrake cable what colour will mine be on a wrx 2001 and also the ignition cable what colour will i need to plug it into
i did buy the hks plug and play harness
Do tourself a favour, put it on ebay and take the money.
Total waste of money im afraid mate, drive it steady to let it warm up for first few miles, drive it steady last few miles to let it cool down. Turbo timers dont allow all fluids to circulate properly and cool evenly so are not worht it.
Not sure about the wires mate I believe they can differ sometimes I have a Turbo Timer I find them handy to leave it running if I pop to the shop saves it powering down the PC :D
Stole this from an American site :) Might help a little.
1. Locate the ignition switch wiring harness
Disconnect the negative battery terminal to avoid causing any damage to the electrical system. Locate the wiring harness that goes to your car's ignition switch. This is located near or under your steering column and will usually be concealed by some type of trim. Consult your car's shop manual for the proper way to access the wiring harness.
2. Wire the turbo timer
Locate the wire on the wiring harness that goes to the constant 12V power source on your car. Use the manual to determine which wire this is. Cut the wire and splice in the red wire from the turbo timer into this wire, using either a soldering iron or an inline connector. Locate a wire on the harness that goes to a 12V ignition switched power source. This can be some type of accessory like the cigarette lighter. Cut this wire and splice in the green wire from the turbo timer with a soldering iron or an inline connector.
3. Wire the hand brake to prevent theft
Locate the wires that go to the emergency brake switch. These should be located at the back of the emergency brake handle under some trim. Locate the wire that activates the emergency brake warning light. Cut the wire and splice in the white wire from the turbo timer. This will ensure that the car cannot be driven with the emergency brake disengaged, since it will turn off the turbo timer, preventing the car from being stolen or rolling away.
4. Ground the turbo timer
Locate a suitable ground for the black wire on the turbo timer. A ground is a metal surface, preferably somewhere inside the dashboard. The ground should be free of paint. Screw the wire to the ground with a round eyelet spliced to the end of the wire.
5. Mount and test the timer
Mount the turbo timer in the interior. The Apexi timer is very small and can be mounted in a variety of places, using double-sided tape to secure it. Start the engine and then turn the ignition to the "OFF" position. The engine should stay idling for the preset amount of time, which is set with the buttons on the face of the turbo timer.
Agree get rid of it.
If you do keep it you wont be able to arm the alarm whilst it is still running unless you are really good with wiring and bypass it.
