Standard front Anti roll bar size on 53 plate Impreza STi
As per the title basically. Anyone know what the standard size is? I'm wanting to buy some uprated bushes for it but can't find the size...
Not got any calipers to measure it mate ?
I took advice from the Internet and it was all wrong !
I think the standard size is 19mm, the uprated ones start from 22mm
if I was going to buy and fit uprated bushes, I'd buy a bigger ARB too
get an open ended spanner and put it over the bar as close to the bushes as you can and that will be the size you want :)
I've just read about that trick before coming back on here. Thanks :)
Unfortunately not got calipers to measure it Stants. Hopefully the open spanner method will work, I'll check with Martin tomorrow at SSS to make sure too. I'm sure he'll know.
And Dave - I've done a lot of research and OEM front and a 22mm adjustable rear seems to be the setup most people recommend/like for fast road use. With most saying get a bigger front and rear (22mm+ front and 24mm+ rear) if you're doing a lot of track use, which I'm not. So I'm replacing the drop links and bushes on the front only.
