04' Outback Clock trip computer thingy not working
Hi, just bought an 04 outback that I'm delighted with however the clock computer thing is totally dead, is this a common fault and are they readly available. Thanks.
Jeff.
eBay or a breaker would be your best bet. Have you checked that it isn't just a loose wire or blown fuse first though?
no but it's going in for a big service on Monday, I'll get them to have a look.
Are you refering to the one in the dash - which does your mileage etc?
Or the one in the centre cubby which covers temp etc
The one in the dash, usually gives an error display when defective
The one in the centre cubby is a known failure item.
One cause is a dry joint on resistor 19, resoldering can sometimes cure it ....
They turn up on the bay, but can cost almost as much as a replacement.
There is a workaround if you do a search, in the forum i found a way to use a non uk spec part :)
I also believe the guy who repairs SAAB SID displays has now started to cover this display too .... if i recall it was between £50-100
for the SAAB SID unit so may be a comparible price
Mart
Thanks Mart, it's the one in the centre of the dash below where the sat nav would go if it was fitted (which it isn't). it's totally dead. I'm aware they appear to be a known failure, there is one currently on the Bay at £90ish which seems a bit steep, I'm not desperately upset it doesn't work but it would be nice to have the car right.
Jeff.
Jeff.
I paid £26 for mine .... do a search, :)
or for £45
http://www.ebay.co.uk/itm/SUBARU-LEGACY-CLOCK-DISPLAY-UNIT-WORLDWIDE-REPAIR-SERVICE-/121432851572
Mart
Once again Mart thanks, the bay link will definitely be route I'll take, I'll ring him on Monday. Out of interest how do you remove them? I'm relatively ok with the spanners but never worked on Subs so be grateful for any tips.
Jeff.
You need to put a trim removal tool (thin piece of plastic) between the box and the dash panel (where the seam around the part is effectivly)
one you pop the tool in you can pull the unit out ...
2 conections normally light & multi plug
Mart
thanks, I'll have a go on Tuesday, car in for big service today, needs 2 x CV joints, timing belt + tensioners, brake pads all round plus standard service parts so expecting a big bill, should be sorted for a while when I gat it back/
I hope it's gone to a specialist as opposed to a main dealer
yea it's gone to small local garage that are very familiar with Subaru's, they rebuild Suub rally car engines so I think they should know there stuff.
Thank goodness ☺ nearly had a heart attack the 1st time I called my main dealer up for a couple of prices
Still expecting a bill of around £750 + but hopefully the car should be spot on after this, love how the car performs and feels so I'm quite happy to spend a few quid getting it how I want it.
Jeff.
picked the car up today ...£1150 for the service plus lots of extras, sounds a lot but it had pretty much everything done and runes like a dream now, hopefully the next service will be simply fluids and filters.
Jeff.
Wow, thats a hefty bill,
What did you get for that?
Mart
A lot, 2 x CV Joints, Timing Belt + Tensioners, brake pads all round as well as work to free off seized callipers, 2 x rear tyres , spark plugs and full service which included quite a few other bits and bobs. The did have my bottom  jaw on the floor but it's been a fair bit of graft fro the garage and they have fitted few shiny bits.
Jeff.
Sent my clock / computer away for repair to the place Mart suggested (see ebay link above) super fast turnaround and it now works a treat. Seems a top bloke too.
