Hi guys going to change the oil in my baby this weekend just wondering what oil you guys use.
This is the engine oil by the way.
I will also be topping up my gear oil again what do you guys recommend.
Thanks in advance
Contact opie oils www.opieoils.co.uk they will advise you the best oil for the level of mods etc plus we get discount, most of us use varying grades of millers oils
What he said ^. My mechanic referred to using millers as "proper behaviour"
There's a really good write up about oils from opie somewhere... The same thing may well be on here somewhere?
Cheers guys what about diff and gear oil are these the same?
75 -90 is what you need, I presume they are the same but I'd double check
