Moss Posted November 7, 2015 Posted November 7, 2015 HI all, I recently put a post on the OUTBACK AWD club forum. Re High - Low Lever? I've since discovered that the pin on the gearbox end of the cable was missing. I'll fix I thought!! Huh Mmm, not much room to get your hands in there; so asked someone I know (a Mechanic on Rally Cars) to have a look at it, he found a pin that fitted perfectly; and selecting Low (lever up and back) no problem. But selecting High (lever down and forward) wouldn't quite select; it left a grinding noise; and was unable to drive in gear. I Can however, select high range by using a bar or shaft of a strong screwdriver to push the connection above the gearbox housing to select high range; and it works perfectly .. So nothing wrong with High or Low Range! I'm thinking the cable has stretched over the years from lack of use, the previous owner only ever used high range on the vehicle. Q, has anyone changed one of these cables? Q, how difficult is it to do? Q, or maybe take it to a Subaru dealer? Q, Would that be an expensive job at a Subaru Garage? Any help or advise on this please. I think Keith Price at Abergavenny is the nearest Subaru Dealer.. Thanks in advance M
WideSam Posted November 7, 2015 Posted November 7, 2015 Subaru dealers may leave you feeling like you've had your trousers pulled down a bit... Have a look for an independent Subaru specialist. They're often worth their weight in gold and half the price of a dealer Sent from my iphone using Tapatalk
stants Posted November 7, 2015 Posted November 7, 2015 Must be some adjustment on the cable mech somewhere like handbrake ?
Moss Posted November 7, 2015 Author Posted November 7, 2015 I was thinking there would be some kind of adjustment. Fingers crossed there is. Thanks for your help. M
Moss Posted November 7, 2015 Author Posted November 7, 2015 UP-DATE, Sorted by putting a thin alloy shim behind the cable arm looking nut; everything works just fine now.. 1
