Newage Subframe Bolts
I'm after a couple of subframe bolts, can't seem to find any? Anywhere know where I can get some or have any for sale? Cheers
Best bet is to find someone who is breaking one. Quite a few scooby breakers on eBay
  • 3 months later...
Hi There
I have a lot of the Subaru nuts and bolts kicking around from various models. which subframe bolts is it. Is it the front or rear subframe? Give me a call tomorrow on 01884 32339 I should be able to help you out with these.
Nice one. It's the front "C" subframe.
Ahh yes I know the ones you mean mainly 14mm and a couple of 12mm bolts. I will see if I can put a set together in the morning, if you would like to give me a call tomorrow after lunch I should have a set put together for you.
I'm only after 2 bolts, there are 2 extra ones on the STI than the WRX. They bolt the subframe and engine cradle together. I will give you a ring tomorrow mate :).
Ok no probs I will see if I can find some for you in the morning.
