How much brake fluid?
Going to be replacing all discs, pads and brake lines this weekend so will be removing almost all the brake fluid before I start. How much will I need to completely refill the system including loss of some due to bleeding? Will 1 litre be enough?
Hi Sandles,
1 litre should be fine. I'd use DOT 5.1
Perfect! Thanks!
