Rear wiper
Hi , when I use my rear wiper and then turn the switch off , the arm stops moving as soon as I turn it off , it doesn't come to rest at the bottom of the rear screen . Does anybody know if there is a way to reset it . Thanks
Maybe take the arm off the motor run the wiper see where it comes to rest the pop the wiper back on in correct position. Mag work could just open up a can of worms
Might be motor that's dying
It just stops on the rear screen in the position when the switch is turned off , it doesn't stop at the same position twice in a row . hope that makes sense !
Had a similar  problem with a land rover discovery , I think there is a a switch in the motor that brings it back to resting  point.
What year is the car ? My foz's wiring just wore through with the constant opening of the boot may not be getting constant power, do the rest of the wiper functions work ?
Hi stants . yes all the normal functions work ,constantly on , intermittent and wash .just stops wherever it is when the switch is turned off .
I'll check mime later as haven't a clue [emoji50]
