clutch needed
hi need new clutch fitted live Walsall any recommendations and price ty
Give these a bell mate. Depending on what type of clutch you want depends on price. Also if you need a flywheel. But should be around the £300 mark fitted for a standard Exedy clutch
http://www.polepositionuk.co.uk/
OK m8 all booked in ty
just an update went to pole positon new clutch and fly wheel £410 good service from the lads  but little judder when pull away see if it will settle if not they will re do  hopefully will be ok  thanks
Should be fine once it's bedded in :D
