Bonnet scoop seal
Hey guys, some of you know that I've fitted an STI scoop to my WRX. Noticed that even tho the bolts are tight it still has a little movement ever so slightly. I think this is caused by the foam seal that goes on the underside which has pretty much perished. What would a suitable replacement be? I've got some thin foam draught excluder, would that do the trick? Ideally want it to stop wobbling and stop water getting in that way!
Yeah I reckon it would do job, I would have said try that if you hadn't said what you were thinking of using
Nice, wasn't sure if it was a silly idea or not! I'll give this a try later in the week when i'm not working and report back!
