Skid Plate Subaru
Skid plate Subaru Forester
Skid Plate Subaru Impreza
Skid Plate Subaru Justy
Technical specifications:
Sump guard for the protection of the: engine, gearbox
Made out of 3 mm thick steel plate.
Screws, nuts, clips, all fastening accessories are included.
Against corrosion all sump guards are powder coated.
The exterior of the sump guard is provided with steel reinforcements, which increases the resistance to impact.
Installation:
Delivered together with the mounting scheme, that will describes the position and order of the accessories used during the operation.
Every car is equipped with factory screw holes for fitting the sump guard, so this operation is extremely simple. It can installed by you, or at any auto service.
For fitting your sump guard you don't need any mechanical interventions on the vehicle structure.
Guarantee and handling of the car are not affected.
