Update on boost control problem
Ok so the last 2 weeks iv been trying to get to the bottom of it, some times it will boost up to 0.7bar wich is wot it is ment to be and out of nowhere it will drop to 0.5bar and go no higher. You can start the car and when you rev the engine you can feel the boost control solenoid clicking and other times you start it it won't there r no fault codes on the ecu. if anyone can help that would be great
Have you put some brake cleaner through the solenoid? Give it a flush through. I can't remember if you have a classic, if so you can connect the two green plugs under the dash and the car will run some basic operations. It will test the fuel pump, cooling fans and boost solenoid. While it's clicking away at the solenoid you can give it a squirt. Make sure to have a cloth below to catch any gunk or fluff.
Already done that we'll twice now and it has not had any effect still clicks sometimes and not others
I have just found it and no that's in there so it's not that
