Blob Jacking Points Front
david1972
It only starts just to the rear of the front wheel arch then goes forward towards the front of the car - I was assuming it was part of the frame so used it on that basis.
What was your picture of - I couldn't see anything like it near either front wheel
Thanks mate; I'll have a closer look again tomorrow before I start putting the rest of my mud flaps on.
Just worried I'm jacking where I shouldn't, due to my lack of know how [emoji15]
Dont hurt to ask mate.allways someone to give advice.best i can say dont jack it on sills or floor of car.if it looks solid nice thick plate then sould be ok to jack.thats why i use that nice thick plate.i'll take a better picture in mornin if you need it as am fittin mudfaps as well in morning.
Not the best pictures mate.but hopefully help you.taken from rear of car.1 the plate for jack on lower wishbone and second is the channel runnin down car that is what i put axle stands on.
Flaps are on; couldn't find anything like that first pic so used where I'd found yesterday without incident. Will observe where it gets jacked by my tyre man when he puts my winters on.
Using rear diff for back end was fine.
Thanks for all your help...Google wasn't my friend this time lol [emoji106]
That's never been under sealed dave I suggest you either do it yourself of or look into paying someone keep it all rust free
Thanks mate...off work in 2 weeks time so will get my local indy garage to do it [emoji106]
Think I'm going to get one of those ice hockey puck type rubber pads with a channel cut out for future and just jack the front corners at the scissor jack points with my trolley jack using that
