KEY problem
Can anyone suggest a solution , went to our 55 plate Impreza wagon this morning, pressed button on fob, started car let it warm up, after switched off and lock it up, later when due to go out the key fob wouldn't work, it had a new battery two weeks ago so I know that's okay any suggestion as I know I can use key pad inside to start car but need to solve why the fob suddenly doesn't work
Cheers
steve
Maybe the battery isn't making good contact or is a dud.
Or battery in fob is dying?
How does the fob die? and if it is when do we get new ones? having to use key pad inside to use the car, isn't ideal plus can not set alarm when you get out
weve tried reprogramming fob no good, turning key in ignition 10/12 times , pulling fuse out still no good
Is it 1 button fob and is it separate or built into key head ?
single button fobs separate to key can be had on ebay cheap and reprogrammed using info on this forum.
fob boards fitted in the key head can be swapped so can buy used ones of those reprogram and swap, is also a company on ebay repair the boards at fixed pricing .What ever solution you use it worth also grabbing a spare fob and programming it also as handy have .
its a one small button key fob, the circuit board is in one part of the fob and battery in the section with the blade of the key
I meant the fob battery, not the cat battery.
