Indicator stalk fix?
Hi guys,
I need a little help if you will.
I have a 98 turbo 2000 with sticking indicator stalks, I was about to order a replacement stalk but then I wondered if that would fix the problem?  Does anyone know if instead there is a cancelling peg on the steering column that needs to be adjusted?
Thanks in advance.
