Seatbelts
hi, I have owned my Subaru Outback since 2001, I now find the seat belts are very weak to rewind, the rear ones are really annoying, as they twist in the guide and jam. I have to actually assist the rear passenger to ease the belt out so that it does not jam. Has anyone a cure for this please ?, thanks in anticipation, gypcoll
Check behind the trim for a twist they are tricky to remove you fold and pull. You can also grease the cassette I'd recommend a silicone spray grease it last a long time and doesn't smell.
Good luck
