Help tuning subaru impreza 1.6
I want to know if it's worth putting a turbo on a 1.6 or swapping the block with a ej20 /ej25 short block with the ej16 heads, I know I would have to have the heads revalved and portent but I don't know what is the best root to go down, thanks.
Don't waste your money save up and buy a turbo model,
You'd need everything from cooling/charge cooling to full exhaust system, boost control ngine harness ecu injectors etc etc I believe the gearbox is different too
