BP5 wagon brake question
Hi guys
hope you are all well.  I've searched online and the forum but can't find the info I'm looking for so hopefully you guys might know.  My car is the following:
2004 Jdm legacy gt wagon, bp5 ej20x 2l twin scroll
I normally get my discs and pads from import car parts and the guys there are great but I'm looking for a disc that won't rust so bad. Ideally I want some EBCs but the guys that sell the ebc just have info on the GT.  So my question is does anyone know the the brake spec (diameter, thickness etc) front and back for the above car?
thanks
not sure if this helps, i get confused with all the model numbers/codes..
2003 BP Wagon ~ GT-B JDM
General Data
Curb weight
1480kg MT - 1520kg AT
Length 4680mm
Width 1730mm
Height 1430mm
Wheelbase 2670mm
Turning radius
Chassis and body
Layout front engine/4wd
Tire size and type
Wheels f/r nd
Tyres f/r 215/45-18
Brakes
Front/rear Brembo 316mm x 30mm / 290mm x18mm
Steering
Type rack and pinion power assist
Overall ratio 15:1
Suspension
Front/rear Strut/Strut
Engine
Motor EJ20 4-cam flat 4 intercooled Titanium twin scroll turbocharged
Hey bud
good chance info is the same but mines not the gt-b it's the 04 new shape GT wagon.  Very hard to get definitive info on this generation ☹️
Mine didnt get the brembo pack pack but I know my front discs are 316mm.
am sure one of the experts will be along anytime soon...:smile:
**goes back to confused step** :huh:
You on 2 pot calipers or the 4 pots with subaru on them ? If it's the 1st should be 277mm and 4pots are 295mm
Hiya
mine are 2 pot with the pistons on the same side.  I know my fronts are 316mm as I've changed them but I was hoping someone had a definite spec.   I've found a page elsewhere that looks like their right with their figures but just wanted to confirm.
