Need help with Instrument Cluster
Hello. My friend has a 2002 Impreza GX Wagon. He swapped out the instrument needles for one's from a newer model because he preferred the colour. Thing is now only the rev counter moves. The speedo doesn't move, the temp needle doesn't and the fuel gauge is wrong and doesn't move. We noticed the speedo first so I checked the speed sensor with an OBD scanner and it's reading just fine. Are there any checks on the cluster we can do to fix this? It's all plugged in correctly. Only thing that seems off is the fuel needle seems very loose but the others seem ok.
Thanks.
