Ball joint fail after less than 2 years
Hello
My car is forester 2008 xt 4eat.
I bought my car 2 years ago and been to the usa at that time so i purchas there front and rear end links and lower ball joints.
Now it has been ayear and half and one ball joint failed and the two front end links failed, all of the place full with grease.
Is there any reason for that, should i buy now only oem parts?
Sent from my SM-G955F using Tapatalk
Tripple 5 ball joints and meyle HD drop links about best we found
ADL also good
Moog not bad .
Most stuff is monkey metal these days .
moog just failed me so i don't think i will go with them again.
Try get triple 5 (555) for the BJ's and meyle HD for drop links .
Meyle been or best links
Here is the moog end links that i just pulled out, i'm very disappointed from them.
I will install whiteline and post pictures.ce4c916d2fb814f0921ceb03d9b99419.jpg
Here is the new witheline end links, tell me please where i'm wrong or everything is install fine.
Both sides, something looks to me weird on the left one. Looks lkke the bushing wants to come out. 0d37648ac53a2bffe282ae155c72b206.jpg65d8af2f7e34a485862a63d8ec799d4c.jpg
probably because that earlier model bushed drop links (up to 2002) and your SG uses jointed drop links .
I have a problem with the whiteline end links after installed and lowering with tein coils.
Sims to me that the end links both side touching the tie rod.
Like they made some rooling to the front of the car and now it is rubing against the tie rod.
What did i do wrong?bf3db5fae90e25e96a288dc5f6e6a896.jpg3f8cda94aee4e5be36225a3ec8452ca6.jpg
@moshe_levy What year is your car ?
As they changed the drop link shape from the ones you have to a lolly pop shape,
The the ones you have are for the sf model , i'm not sure if they changed them on the sg or sh model to Lolly pop ones
I have the sg model 06-08, (08).
What is the lolly pop?
Like ball joints?
See my previous post .
Don't now what ride quality and life of teins will be on your roads :-SFor road I would of gone kyb excel g on custom springs with minimal drop .I would of used meyle or tripple5 drop links .
2002 onwards (SG onwards) should be balljointed drop links
Ones like you have fitted now are for earlier models and what he calling lollipop ones ...
As long as i can see it's fit my car as well...4c5c9b27c6739c2dc6b033631c1207a7.jpg&key=32d1da072ef00e9e55ca970ddaabb4c887527d845c6134cec5324b84e542ca12
2adfb8e92aba145dbee1035af0391b39.jpg&key=5d7b9f98d18afca3c32eeec0f3df207846c1e8e8ff640557b809a7ceedb7719a
Yes but not very well.
I had a customer who done a sg with the oem links from early subarus same as whiteline and they align at poor angle plus length differs so swaybar max/min travel positions differ  ...Customers sg went back to ball jointed ...
