2002 WRX Dimmer Questions
Hey all, first question post!!
I have a 2002 WRX, and am wondering what the dimmer does on the stalk.
I thought it dimmed all the gauges and the HVAC, but I have replaced a bulb, and since that the dimmer only seems to do the clock, the odometer and the ambient temperature. Is this right or should it do the speedo/tach etc as well?
Second question, if it is supposed to do that what should I be looking for to fix? I was considering LED replacements but don’t like the fact it won’t dim as I do a lot of night driving.
Thanks in advance!!
Hi mate had a 2002 wrx myslef as my first scoob lovely motors. Im sure its only there to dim clock/odometer ect as you stated, basically all non essential info. Not sure if the bugeye does but my blob dims the Stereo if i hold its power button in aswell. If in doubt however = owners manual.
Thanks Ross, I checked the manual but it just says instrument panel, the issue is mine doesn’t do all instruments, just the bits I said (including clock). I’m sure it did the whole lot before I blew the clock fuse (now replaced) being stupid.
I’ll have to find a bug close by and check.
Ah cool, thanks Ross, mind put at ease. It’s one of those odd things that I was sure it dimmed more before I blew the fuse, but just the mind playing tricks.
Have a good weekend, I’ll continue to tinker with some other bits...
