DIY Morette headlights for Impreza "BLOBEYE"
Probably everyone knows how difficult it is to find the Impreza "BLOBEYE" Morette headlights. I've been looking for them for a long time, but unfortunately, I didn't find anything suitable. Then I decided, if I can't find it, I'll make it myself! This is how my project came about.
The aim of the project - creation of Morette headlights copies using available light modules. And maybe, the headlights what I make, will be interesting to someone else too
Starting point:
- Subaru Impreza "BLOBEYE"
- the opportunity to borrow original Morette headlamps from a friend
- Skills in working with fiberglass
I will not go into details, therefore below it will be more pictures and just a little text
Ok, Let's go!
1. Making masks copies:
- genuine Morette headlights:
- made fiberglass shapes:
first copy of masks ready:
- sizes identical to an original (my masks on genuine headlights):
to be continued.....
Continuation...
2. Light module choice:
- Of the available cars with round headlights, the choice is not too large...
- For low beam my choice stopped at the BMW E-30 - desired diameter, compact anchorages, available used:
- For high beam,  I did not find anything from known cars in size, therefore I chose Hella universal modules:
Turn indicators - universal Hella modules:
3. Bracket fabrication:
- This will be the most difficult process... copying the original with tape:
Scanned in the computer:
Draw in graphic editor:
- Print and glue it on a metal plate and cut it out:
The "alpha" version of the bracket is ready for measurement:
to be continued...
4. Fitting on the car:
- on the car:
small problem -  not fit the light module:
- after all adjustments look of the bracket slightly changed:
Editing file and send it to a laser cutter:
to be continued...
5. Conclusion...
- cut out, folded, screwed:
- painted with black primer:
- on the car:
- from inside:
- Work with project "beta" version finished - bracket still need minor improvements, but it will no longer affect the overall look!
Thanks for Your attention 😉!
If any questions, feel free and ask!
As the title of the topic was the abbreviation "DIY" , so a little about the useful light modules.
1. Low beam:
Low beam (R):
Hella white: 1BL139278001
Hella black: 1BL139800011
Low beam from DEPO: 444-1117 R-LD-E
Low beam (L):
Hella white: 1BL139277001
Hella black: 1BL139799011
Low beam from DEPO: 444-1117 L-LD-E
- Parts for Hella low beam light modules:
     Case with glass (R):
          White: 9BG135942011
          Black: 9BG139802011
     Case with glass (L):
          White: 9BG135941011
          Black: 9BG139801011
     Hella linse L=R: 9DR136958021
Hella low beam modules are switchable LHD or RHD!  About DEPO modules, I don't know.
2. High beam:
High beam, L=R:
Hella chrome: 1K2 006 147-051
Hella black: 1K2 006 147-041
Hella white: 1K2 006 147-031
3 Turn lights:
Turn light, L=R: Hella 2BA008221007
Continuing  about the "beta" headlamp set...  arranging electrical wires:
What's next!? To continue working, I plan to put this set on sale,  better than DIY (without light modules) -  because the light modules will also be useful for set # 1 😉
PS
Of course,  if there will be interest, I can also sell with all modules and then buy everything again for the next set...
  • 2 months later...
